for a plug chop can i just have someone lift up the grab bar and me go through the gears because i dont have enough room to get into 6th
you must have a load on the engine to get a proper plug reading
damn, you better hope their strong and can hold it up for a long time with the hot exhaust gases and smoke, if not you'll be going for the ride of your life. :banghead:
on a serious note: 'Sprntr81' is correct.
Plus free reving an engine is hard on it. Try punching the air has hard as you can. That is what you do to a motor by free reving it.
it doesnt work. dont try it. if you dont have room go to a dynometer. if you cant do that, it might not be as accurate but park up against a tree and power brake it through all the gears. and make sure you video it because that would be great to watch. :cool: I dont sit on it, .stand of to the side.
