lildeezul Posted March 29, 2007 Report Posted March 29, 2007 i got one bolt with vice grips the top one near the swingarm. but the bottom bolts near the kick starter, i cant get off. i dont have an impact driver!!!!!! i tried using vice grips but wont work. What else could i do. could i use a impact gun with a small socket that fits a screw driver bit??? some help, its not stripped all the way, but kinda b Quote
wesw Posted March 29, 2007 Report Posted March 29, 2007 (edited) but the bottom bolts near the kick starter, i cant get off. hmm first off the kickstarter is on teh clutch side of a banshee. you will most likely need to get a impact driver or put a screw driver bit in a vise grip and beat on the grips but impact driver will solve the issue if you havent rounded it too much get a set of allen bolts to replace them you still wanting that peatcock or what>>>>>>>>>>>>>>>>>> Edited March 29, 2007 by wesw Quote
lildeezul Posted March 29, 2007 Author Report Posted March 29, 2007 naw man dont worry about it for now, im test it on the track, with gas, then ima run a 6mil, then from then ill use alky. srry bout the inncovinence. also i mean gea shifter, not kick starter lol. ill try the vice grips and the screw driver bit Quote
375hp banshees Posted March 29, 2007 Report Posted March 29, 2007 naw man dont worry about it for now, im test it on the track, with gas, then ima run a 6mil, then from then ill use alky. srry bout the inncovinence. also i mean gea shifter, not kick starter lol. ill try the vice grips and the screw driver bit tap on the screw w/ A punch in the dead center to jar it ...also take out all the other bolts & try to spin the whole thing A little to break it free, that way it will losten up A little & won't strip more Quote
lildeezul Posted March 29, 2007 Author Report Posted March 29, 2007 i got it off, i used a drive bit, and a rachet, thanks should i repalce these with botls, or allen heads screws. im thinking bolts?? Quote
fastrthnu Posted March 29, 2007 Report Posted March 29, 2007 i got it off, i used a drive bit, and a rachet,thanks should i repalce these with botls, or allen heads screws. im thinking bolts?? anything will strip over time no matter the shape, get something that is made out of high quality material(chrome moly 8740) or stainless steel that work. At least its very hard, or wont rust. Quote
