hey man the same thing happened to me i just bought this yamaha banshee 2001 not even 3 hours a go and i got it home took it for a ride and it was running fine the i took it down the dirt road and i was flying and then the back tiers locked up and then it shut off then i tried to kick it over and it would not kick over
does anyone know what i could do to get it running again or fix it?
it sounds like it locked up.. from where theres not telling, but if the bike was brand new and your ripping on it then it may be the top end..
first think i would do is pull the clutch cover off and see if its not something under there that is the problem..
Edited by lowriderb
hey man all i know was i bought it today it was used and i got it from pawpaw cycle MI and they said it was fine but i know i was flying but i dont know how much is a new top end
like i said i would pull the clutch cover off and see if theres anything in there that is not right...
the next thing i would do is pull the top end of and see whats what in there if there isnt anything under the clutch cover that is wrong..
im sure there are some pics of what everything is supposed to look like around here..
allright thank's man you have a good night and ill hit you up online tomorrow k
probally 1 of 2 things. either a peice of clutch broke off and its jammed up, or something happend to the piston, maybe a ring came loose and its jammed between the piston and the hole going out of the exhaust.
sumtimes 2 strokes just seize from heating and expanding there doesnt have to be anything wrong with the motor it will happen expecially if its new. Dirtbikes are alot easier to pop loose than a banshee id say loosen up the head so theres no compression and try to kick it over as hard as u can
I Had the Kick Prob Got it tor apart and found the rings broke in on side
i have never had a motor with nothing wrong with it lock up , if its locked up it time for a rebuild.
i wouldnt try poping loose kicking it as hard as you can , you are going to do more damage .
loosen the head up ? wouldnt be easier to take out the spark plugs
ok.. kickstarter locked up... take the head loose and kick it as hard as you can?? wtf kind of thinking is that?? :down: you have no idea what you could be doing to some of the other parts in there if its something in a bind that you dont want screwed up any worse..
start with the easiest things first.. pull the side cover off and see if anything is not right.. then work towards the top end if nothing is found under there..
