peak-j Posted March 27, 2007 Report Posted March 27, 2007 Just like the title says, I am kind of wondering how much time I have before a skirt decides to give way. My mods are below. Should I expect them to last a while or not. Stock pistons just worry me when I start adding mods, and I'd like to know if anyone has had any troubles with the stock ones breaking a skirt very often. Thanks for any input :biggrin: Quote
Bansh-eman Posted March 27, 2007 Report Posted March 27, 2007 its hard to give you an amount of time... for some they last years and some days... it is vry ez to say that as you add mods your rolling the dice for sure... if you hav the money id just invest in some new pistons... if you wait until they come apart your going to spend more getting your cylinders fixed. Quote
blowit Posted March 27, 2007 Report Posted March 27, 2007 its hard to give you an amount of time... for some they last years and some days... it is vry ez to say that as you add mods your rolling the dice for sure... if you hav the money id just invest in some new pistons... if you wait until they come apart your going to spend more getting your cylinders fixed. We have never had any concern of OEM pistons breaking skirts if they ARE in spec. The problem is most people will wait until it is too late for a rebuild. When the piston reaches TDC and BDC, the rod changes loading direction thus causing a rocking motion in the piston. If the tolerance is excessive, it will not really rock, but bang against the sleeve until it breaks. Tight pistons=no worries. If you don't know if your motor is within spec, you better find out. We have run casted pistons with 20psi under boost without piston failures. Brandon Quote
FireHead Posted March 27, 2007 Report Posted March 27, 2007 We have never had any concern of OEM pistons breaking skirts if they ARE in spec. The problem is most people will wait until it is too late for a rebuild. When the piston reaches TDC and BDC, the rod changes loading direction thus causing a rocking motion in the piston. If the tolerance is excessive, it will not really rock, but bang against the sleeve until it breaks. Tight pistons=no worries. If you don't know if your motor is within spec, you better find out. We have run casted pistons with 20psi under boost without piston failures. Brandon Like Brandon and Bansh-eman said, stock piston like is a fairly subjective thing that depends on alot of variables. If the engine is completely stock with regard to the pistons and bore, then a compression test may be a good indicator of the health of your pistons. What Brandon stated holds true for all types of pistons in almost all engines. The fact that the Banshee engine is almost square can allow you to get away with alot more piston, bore, and ring wear than is possible in many other engines. :geek: Quote
peak-j Posted March 27, 2007 Author Report Posted March 27, 2007 Thanks guys, I checked the compression before I added the 20cc domes and it was 110. After adding the 20 cc domes it is now 150 each cylinder. Quote
dajogejr Posted March 27, 2007 Report Posted March 27, 2007 110 is low, adding domes will only make that motor wear faster. My advice is get a fresh top end.... Or...if the pistons and cylinder are within spec, at least re-ring and hone it. Should be upwards of 120PSI on a fresh, oem port build/head...at or near sea level. Quote
FireHead Posted March 27, 2007 Report Posted March 27, 2007 110 is low, adding domes will only make that motor wear faster.My advice is get a fresh top end.... Or...if the pistons and cylinder are within spec, at least re-ring and hone it. Should be upwards of 120PSI on a fresh, oem port build/head...at or near sea level. Yeah, what he said. :thumbsup: Quote
peak-j Posted March 28, 2007 Author Report Posted March 28, 2007 Thanks for the replies, just going off the cylinders measurement they were still ok, not to sure on the pistons though, I couldn't get a very accurate reading with the cylinders on it. I looked in the cylinders and they both have the cross hatches in them. The pistons, just looking from the intake and exhaust ports didn't have much wear on them. I know that isn't the way to tell though. Possibly just a little wore rings ya think? I don't really have the time to tear it down right now because I'm building a house and I'm going to LS for Rattlesnake hunt, but I'd like the motor to last atleast that long. Quote
Bansh-eman Posted March 28, 2007 Report Posted March 28, 2007 rattlesnake hunt? man thats some redneck shi tright there if iv heard any ! lol Quote
FireHead Posted March 28, 2007 Report Posted March 28, 2007 rattlesnake hunt? man thats some redneck shi tright there if iv heard any ! lol If you think that is redneck, wait until you hear the story behind it. I remember reading about it in am agazine, but I will let some one else from around the area tell about it. :thumbsup: Quote
peak-j Posted March 28, 2007 Author Report Posted March 28, 2007 (edited) rattlesnake hunt? man thats some redneck shi tright there if iv heard any ! lol You won't see me doing that shit either, I'm not that damn redneck!!!!!! This is my first year down there, I'm going for the dunes, not the snakes. :biggrin: :biggrin: To see more go to waynoka.com Edited March 28, 2007 by peak-j Quote
chronicwatson Posted March 28, 2007 Report Posted March 28, 2007 ya i got six years out off my stock topend so i'm sure you will be fine Quote
