ok... went out to start it and it kicked on 1 st kick andrev for 3 secs and shut off. now it wont kick back over.
Check plugs and they were dry.
It happened this weekend also and i pushstarted it and then it ran fine.
can anybody tell me whats going on im getting pissed at this thing.
Make sure you are getting fuel to the carbs. I had a problem a bit ago just idling it would do that and I wasnt getting fuel to a carb. Just a thought.
I try and start it and let it iRev for a few mins. It ran great last time i rode it which was about 2 weeks ago. It seems that im not getting fuel because it will idle great but then it will bog down and shut off and it will be a bitch to start. how do i correct the Fuel getting to the carbs?
Should i just take my carbs off and clean them?
Also the T.ors kit . what is your guys Idle screw set at . "the brass one that we had to drill and tap?
I Dont know what to do and just want it to run fine for this weekend because im going riding?
anyone
Take the bowl off the bottom of the carbs, and spray carb cleaner through the pilot and main jet passages. Also clean and inspect the needle and seat that the floats attach to, and make sure the floats move freely. do this one carb at a time, and see if that works.
carb adjustments (stolen from someone else on the board)
first...with the idle screws completely removed, remove the airbox (makes it
easier to see and work on). Make sure with the idles screws removed both carb
slides fully bottom out and seat with no throttle. Then...slowly move the throttle
and make sure they move up at the SAME TIME.
You use the adjusters on TOP of the carb caps for the syncing of them.
Next, place each idle screw in. When it touches the slide, stop. Back it out,
turn it in, etc. Once it is JUST at the point of touching, turn that screw in
2.0 full turns, and lock it down. Do the same on both.
Check the sync on both of them again....
Put it back together....
Warm it up...and set your air mixture screw next. Start with the air screw
out .5 turns from the lightly seated position. Keep turning it out until you
get your highest idle, only go .5 turns at a time.
After you turn the air screw out, WAIT 20 seconds for the adjustment to take
place. When you get your highest idle, then...adjust it up or down with the
idle screws....
  • 1 month later...
what does it mean if once my idle screw is touching i can only go half a turn b4 it bottoms out?, time for new idle screws?, if so where do i get em?
thanks for the help
Sean
