today it was around 40 degrees outside it would like load up really fast at idle i half to have the idle screw turned all the way in for it to barley idle and it would stall after a min. of idleing... im goin to be rideing at 665 feet around 50 to 80 degrees is my jetting to rich for this or do you think its somthing else? the carbs have 270mains 30 pilots and the needle is in the 3rd clip..i dontkno how it performs yet havnt had a chance to take it out yet trottle responce seems slow and sluggish tho...thanks for reading my post :thanks:
What are all your mods? Air box setup?
pro circuit pipes,boost bottle and a k&n with the lid on
30 pilots?!?!?! That's HUGE dude. You should probably be more lik 25 if you don't have any porting. The mains are right though, and then you should mess with your idle screws and carb caps(if you have TORS removed, which you should) to get the bike on spot. Also, where ae you located, elevation?
Yeah, that pilot is way way off, you should either be at a 260 or 270 main depending on temps, 270 if it's below 50, 260 if it's warmer. Try a 25 pilot, with the air screws 1.5 turns out or so, then play with the idle screw a bit.
Yeah, if your needle is stock, keep it at the middle clip, and then go with the jetting suggestions above.
By the way, when I saw your thread name, I thought of Borat, Wow wow wee, I need some jettings help, yah!
Your jetting is very close....Try pulling the stock lid off and go from there. You'll notice a lot more low end response and pull...If your air screws like to be all the way in, then your not rich. You can mod the lid by cutting the last 1.5" of the end of the lid right behind the clips so you still have all 4 clips....the stock lid really holds back the shee....also make sure you still have the equalizer tube on between the carbs, cutaway in the slides are facing the air box and carbs are in sync...
I agree with the above....I live in MI, and all my buds bikes used 25 pilots if they kept the airbox, 27.5 if they completely removed it.
So...30 pilots would explain the loading up at idle/low speed. Drop stock pilots back in...
The rest of the jetting sounds close...
Does one of your buddies run pc pipes? Pc pipes really like a rich pilot. He stated that it won't idle w/o the air screw being all the way in, which tells me that the shee wants to be richer....I don't think he has a pilot issue if thats the case.
I think there is something else at hand.
Reread his post...partner.
The first post says his idle screw is almost all the way in, not the air screw....:)
That tells me it's trying to get more air in (via a raised slide) because it's getting way too much fuel.
Unless he got the idle and the air screw confused....:)
Rob, please confirm whether you mean the actual idle speed screw or the air mixture screw.
its my idle screw....my air screw is 1.5 turns out.....my carb slides was in backwards :blink: the bike idle really nice and revs nice not spiting oil out of the pipes anymore... wonder how long the guy was rideing it like that befor i got it :biggrin: got it for 1,950 Picture.jpgbansheeshavedfenders002.jpgbansheeshavedfenders001.jpgcut the fenders to the resized pics make the cuts look messed up... just installing some stuff that needed to be replaced rear axel bearings,front bearings,tie rods,front & rear brakes,clutch cable
Edited by rob8718
