quick ?
i'm looking at buying a set of used f shocks for my shee
he claims they were set 4 dune
i ride trails
what are the diferances btween trail,mx,dune
are these gonna b to soft?
will they work 4 now or should they b revalved right away
thanks in advance !
They should work fine for trails, they would be too soft for mx though I'm sure.
Rest assured they'll perform leaps and bounds over the stockers. :yes:
Couple things make sure they are right for your weight. Are they compression abd rebound adjustable? If they are you will be able to get them really close to trail ready. What kind are they? You can have most re-valved to your ride style for under 150 bucks usually
If they are dune revalved they should be extra soft. MX is the hardest. Desert is the second softest. trail is in between.
He is right about in the middle. My works pro triple were mx and were harsh on small bumps at slow speed. Mx is a high speed set up seems to ride nice at high speeds. My axis are for woods racing and are lot more plush. Dip hard in braking and turns.
