boss intake
i have these ready to put on my shee. i brought them because my standard intakes started to splitt . i was just wondering if u guys put any thing inbetween the aluminium part with the cross over built in and the rubber boots .
when i recieved mine the rubber boots where not attached to the aluminium part . so i have to screw them on my self. i just want a good seal with no air leaks
what do you guys do?
boss intake
You shouldn't need to put anything in there, The boots have around ring feature on the face that seal it up when it's compressed. I believe that the rubber boots for the Boss manifold are a standard Mikuni part. :thumbsup:
I always use a skim coat of high temp RTV on anything intake...
Just my .02.
Orings can leak too...
i am with daj on this one too..... a little ounce of hi temp RTV (prevention),is worth a lot more than a pound of melted pistons (cure)new ones !!!!!!
sorry fire head but i am disagreeing with you on another subject!!!!!!!!!!!!!!!!!!!! :notworthy::notworthy::notworthy:
I even put a thin...thing coat on all orings in my cool head. One it helps them stick better and not fall out when installing, and two ...it helps seal.
My brand new head leaked out the back elbow from the head to the water pump...and yes, it was tight.
Lil dab of RTV on the ORing, no more leaky!!!
i did also ,thin coat,better to be safe.
No worries about disagreeing with me. I am wrong alot.
My problem with putting RTV on an o-ring seal is that the groove for the ring is specifically sized for the compression of that ring. Putting RTV on it will prevent it from sealing properly. With that siad if the o-ring groove was sized by just grabbing what ever endmill looked close from the drawer, then RTV might be doing it a favor.
Back to the boots, I still don't think you need RTV, put some grease on the sealing face if you are really worried about it. :thumbsup:
Edited by FireHead
Are you guys talking about the silver tube piece that goes in the holes on top of the carb boots that connect to the cylinders? Im new to all this banshee stuff and just trying to learn the terminolgy (sp?). If you guys are talking about what I think you are I was wondering the same thing if they needed to be sealed when put back in the mounting holes.
what your talking about is the cross over tube. you can waste 30.00 on a boost bottle there. you can leave it stock, you can get an internal crossover like boss,or some seal them off.. :beer:
