no you have a little silver squar box screwed right next to your cdi... thats your electrical regulator... that will keep your lights and other components from burning out ... thats of course assuming that its working right :)
to be honest id say get a 200w ricky stator.. they are more then enough power...
The ignition side and the lighting side of the stator are completely different....
I've never heard of an Electrex stator, but everyone and their brother has heard of Ricky Stator.
Some have reported problems with their 200W setup...I personally don't run lights, so...when i bought an all new ignition, I got a run of the mill stock W stator....
RS is very, very good about warranty and customer service. I've talked to Ricky on the phone personally...and he was as nice and personable as could be!!!
The regulator does not effect the CDI at all...it is for the lighting only.
im not sure thats 100% accuate dave....
the regulator plugs into that blue wire that goes into your cdi if i remember correctly? then from there all your power goes to coil and lights?
im no electrican by any account... and im trying to go off of what i remember reading and seeing in diamgrams while redoing my wire harness...
could be wrong?
so do I need a stator to run my machine? I have been waiting for one to get it back together and tuned.... can I just run without it for now? I dont think that sounds right either???
Edited by hollisatp
Yeah, thats what I thought...... they sell the stator in RMATV for $165 for a 250w model, they also have a 270w model. But back to one of my original questions, how much power does the bike use for spark and what is left for the lights? What about a CDI upgrade?
im not sure of the exact amount it takes to power the ignition system... but i know that a 200w stator powers a set of 55w trailtech lights and my ignition with dyna cdi and a nology coil fine...
the cdi doesnt make any stronger spark... a coil will, the cdi if programable can have your timing advancement or retarded controled over your rpm curve ... where as a timing plate is static...meaning +4 degrees at 1000 rpm and +4 degrees at 9000rpm
where the programable cdi comes into play... you can advance your timing like +15 at low rpms to get that bottom end your bike lacks then as your rpm range climbs the amount of advancement decreases to give you back some of the top end timing that you cant get from the static plate...
Edited by Bansh-eman
could be wrong?
I can tell you I ran my bike all year last year...no recitifier, no lights....and it ran just fine no issues.
So...it may or may not hook into the CDI, or...it may hook into the CDI for ground purposes.
But, I'd think if were important to the CDI, the bike wouldn't run, or would run poorly...
I can tell you neither of those were the case in mine last year, both with a stock CDI and my Dyna...
