I ride mostly on the mountain I live on at 2800-3400 ft. I have never wound her out in 4th gear as I don't have room. I run out of trail way before I run out of gears. In the posted instructions on doing a plug chop it says to wind her out in top gear. I am guess it would be ok to just go with 4th as opposed to 6th?
yes that would be fine its the rpm that matters, you do live on a street? wind that fucker up, down the block and read your plug
Yes but our roads are steep and twisty. I have to slow down for curves as my shee don't turn when front wheels are off the ground, which is pretty much every time it comes on the pipe. I probably have no business with a shee but I ascribe to the Stroker McGurk theory which goes: If some is good and more is better then too much is just about right!
The more of a load on the motor will require more fuel, so if you do a plug chop in 4th gear, you might find yourself lean in 6th gear.
