i just bought a banshee and it is stock besides bored a bit and fmf pipes. anyway it rips and runs great when on the throttle but at idle it lopes and stalls like right away. i know it is a carb problem and want to know what you people think i should try? also the right cylinder does foul out to so i think that carb with the issue.. any info great before i try anything. i bought it like this. but on the gas runs good but just stalls right out when off the gas and when it does idle for 2 seconds or so ots high and then low then real high and then low and stalls. please respond. thanks
this guy has a great post http://www.bansheehq.com/forums/index.php?showtopic=47286 . I would check out the pilot jets and needle position. Mabye a clogged pilot or to low of needle. Check out his post it has a lot of info.
hey thanks for the tip. also anyone know if that stock kill switch could do this? i opened the top of the throttle case on the thumb throttle and there is a little button that the throttle hits all the time when you let go of the throttle and there are like burn marks from like a spark jumping there. could this cut the engine out when it hits this little switch????
i will try it tomorrow, i took the switch out and will see if it runs without that there.
if anyone knows if this is like a kill switch please let me know then i think i know why it dont run. thanks
Sounds like you still have to TORS on your carbs, and do you have idle screws installed in your cabs, sounds like you don't, if not rip the tors off and then play with your jetting.
yes i am going to disconnets all them wires, i think that is what is not letting it idle. i just need to disconnect all the wires right?
my banshee wouldnt idle when i first got it , in the front of the bike next to the ignition coil is a little square black box , unplug that piece of shit , when i did that my bike idled perfect , unplug the plugs going to the carbs too and you should be good,
