MILODUKE
Everything posted by MILODUKE
  1. hi what do you think my banshee needs. its smoking white bad and running bad. also water is in the trans gear oil. i did replace the head gasket and did not do anything. help
  2. yes i am going to disconnets all them wires, i think that is what is not letting it idle. i just need to disconnect all the wires right?
  3. hey thanks for the tip. also anyone know if that stock kill switch could do this? i opened the top of the throttle case on the thumb throttle and there is a little button that the throttle hits all the time when you let go of the throttle and there are like burn marks from like a spark jumping there. could this cut the engine out when it hits this little switch???? i will try it tomorrow, i took the switch out and will see if it runs without that there. if anyone knows if this is like a kill switch please let me know then i think i know why it dont run. thanks
  4. i just bought a banshee and it is stock besides bored a bit and fmf pipes. anyway it rips and runs great when on the throttle but at idle it lopes and stalls like right away. i know it is a carb problem and want to know what you people think i should try? also the right cylinder does foul out to so i think that carb with the issue.. any info great before i try anything. i bought it like this. but on the gas runs good but just stalls right out when off the gas and when it does idle for 2 seconds or so ots high and then low then real high and then low and stalls. please respond. thanks
