ClimbAnyHill Posted January 27, 2007 Report Share Posted January 27, 2007 I just got the ModQuad Case Saver & comes with three screws & replaces the shift drum cover. The Shift Drum Cover has a rubber seal & when removed a bit of oil dripped out, Is this normal? I put the Case Saver on but the screws seem a bit too long, Am I missing something here? Am I to apply a seal behind the Saver or something to hold this oil in or is the oil not needed. Thanks for the help. Here after i cleaned the oil away. Quote Link to comment Share on other sites More sharing options...
Bansh-eman Posted January 27, 2007 Report Share Posted January 27, 2007 you dont take off the old cover... you just put that case saver on top of it and the new bolts will reach over both... Quote Link to comment Share on other sites More sharing options...
ClimbAnyHill Posted January 27, 2007 Author Report Share Posted January 27, 2007 :: Shit!! I was told to remove it! :wallbash: Thanks, I'm going back out there to finish this thing! Quote Link to comment Share on other sites More sharing options...
Bansh-eman Posted January 27, 2007 Report Share Posted January 27, 2007 :: Shit!! I was told to remove it! :wallbash: Thanks, I'm going back out there to finish this thing! nope it stays on... if not that hole in the center is open to let elements into your shift cam.... the oil is k thats just the oil from lubing the shift cam when its moving around inside... Quote Link to comment Share on other sites More sharing options...
ClimbAnyHill Posted January 27, 2007 Author Report Share Posted January 27, 2007 I put this thing together the right way, screws are in but it's a bit loose. Is it supposed to fig snug? I'm throwin some washer's in there. Quote Link to comment Share on other sites More sharing options...
Bansh-eman Posted January 27, 2007 Report Share Posted January 27, 2007 humm... shouldnt need washers... mine went on there nice and tight.... Quote Link to comment Share on other sites More sharing options...
man27 Posted January 29, 2007 Report Share Posted January 29, 2007 I put this thing together the right way, screws are in but it's a bit loose. Is it supposed to fig snug? I'm throwin some washer's in there. I just put mine on it fits great no washers!!! :thumbsup: Quote Link to comment Share on other sites More sharing options...
bentvalve Posted January 29, 2007 Report Share Posted January 29, 2007 (edited) i just installed mine too..yeah i had just about the same thing with the bolts but i just tightened them down..no leaks so i guess its good. don you know i don't care how many times i see those titts... man it never gets old!!! Edited January 29, 2007 by bentvalve Quote Link to comment Share on other sites More sharing options...
BigRed350x Posted January 29, 2007 Report Share Posted January 29, 2007 You might think about replacing that o-ring when you do it. Try not to re-use o-rings, and since you have the side cover off, might as well replace it. Its like $.30 down at ace hardware for that o-ring. Quote Link to comment Share on other sites More sharing options...
