Tonight I tore the shee apart. Getting ready for the new cylinders from FAST. I got the first piston off no problem, then came the second one. I grabbed the circlip and got it out, but then all i heard was ding ding.....the circlip was no longer in my needle nose. Its now in the bottom of the cases resting against the crank. but dont worry hopefully this is were the magnet will come in handy. Hopefully i get that bastard outta there and dont have to split the cases to get it out.
:shoothead:
ive done that before,and i did use one of those antenna looking magnets,and it work great...... :banghead:
well i couldnt find my telescoping magnet....like usual when u need something its nowhere to be found.
but dont worry, i just went back out there and used a little pocket screwdriver with a magnet on the end and i got it out!!!
Worst case scenario, take the engine out and turn it upside down.
glad you found it.. and for anyone that reads this.... learn from this.. stuff some shop rags around your rods at the case to keep the clip from falling into the case..
Yep, a little preparation now saves you so much time and headache later................ :thumbsup:
i did that once couldn't get it out and didn't want to pull the motor, so i filled them with fuel and then stood the shee up on it front end and it came right out with no problem. but now i always stuff shop rags in there
Definitely! Amongst other things such as piece of gaskets, dirt, debris, etc.
Whenever I have anything exposed like an open cylinder, cases, carbs, I always stuff rags in there to keep it safe!
Rags are good! :thumbsup:
