Bigkahun74
Bigkahun74's Achievements
  1. i was at attica on dec 30th and it wasn't to bad as long as you stayed outta the usual muddy areas. but since then they have had rain and snow so it's probably a slop hole right now.
  2. i did that once couldn't get it out and didn't want to pull the motor, so i filled them with fuel and then stood the shee up on it front end and it came right out with no problem. but now i always stuff shop rags in there
  3. that seems way to low compression for 18cc domes ported or not. i got a drag/dune port on my shee with a pro design cool head running 19cc domes and my compression is 175psi and i'm in northwest indiana (1 hour southeast of gary,in) and i have a craftsman compression tester
  4. i use aviation fuel with amsiol at 40:1 ratio in my shee. the av fuel is 100 octane and i have 175psi of compression in each cyl. i get the fuel from my local airport thats 2 miles from my house..
  5. if your cdi plug and your stator plug don't match you could always cut the plugs off and hard wire it all together. just my opinion
  6. i'm working on my buddies 2000 shee, it has pro circut pipes, lightened flywheel, bored .20 over, k&n air filter, ported, 300 main jets.. it starts 2-3 kicks everytime, but once i get into the powerband and get through some of the gears it falls on it's face and runs like shit. the right cly kinda crackles and it kinda sounds like it's sucking air to me, but i can hold the throttle wide open and the thing barely moves. :: i need help
  7. how much for the flywheel and stator?? shipping to 46534 shipping should be $8.10 for a flat rate box..
