Hi everyone, i can have a good price on a 2 in 1 carbs setup but it come with a 36 mm carbs. I did some research and found different opinions. So here is the question again, Is it going to do good on my bike or not ? Thanks
What type of 2into 1. If it's the Trinity I would stay away. They are not good for top end. If its the aluminum tubular like mine they work good. If your ported minimum dune port you need 35. If your cylinders are stock the 36 will be too big unless your have a drag port.. Edited by Crazy05
It ought to work ok if you have some good bolt ons to help it out. Hopefully the carb is at leadt a flat slide, and not a lectron though.
with the mods in your sig a single 34mm would be ideal. I think a 36 would just be to big of a carb. If you can get that good of a deal on it buy it and either try to trade for a diffrent setup or sell it and make money for a smaller setup.
Thanks guys for your inputs, but i didnt buy it, it was on ebay and the bid went to the roof. Its like the 3 or 4, 2 in 1 that i watch on ebay ending at 600$ used
