Devans Posted January 8, 2007 Report Posted January 8, 2007 Hey guys just tore down my top end to get it bored, the heads were stuck on pretty good.. The gaskets smeemed to just stick on, i thought they would stay one piece, instead it stuck and ripped. Any tips to removing the excess gasket? Quote
bentvalve Posted January 8, 2007 Report Posted January 8, 2007 razor blade,little wire brush.just don't dig any holes. don Quote
BigRed350x Posted January 8, 2007 Report Posted January 8, 2007 Find the biggest grinder you can and go to town on it. :thumbsup: Personally I just use a wire-wheel on a drill and a razorblade. If you do use a power tool of some kind don't stay in one spot very long and make sure you use a soft material so it doesn't "grind" away anything off your head or cylinders. Quote
Devans Posted January 8, 2007 Author Report Posted January 8, 2007 Find the biggest grinder you can and go to town on it. :thumbsup: Personally I just use a wire-wheel on a drill and a razorblade. If you do use a power tool of some kind don't stay in one spot very long and make sure you use a soft material so it doesn't "grind" away anything off your head or cylinders. lol red, your just a big joker today arent you? :yelrotflmao: Is there any solvent i can get to soften the gasket up, its stuck really bad on my cases, i got rags in the hole but kinda scared of getting shit in there... Does everyone have this problem? Im going to try the razor blade, then if it doesnt work ill try the dremel with a soft wire bursh.. Quote
Karzy5150 Posted January 8, 2007 Report Posted January 8, 2007 lol red, your just a big joker today arent you? :yelrotflmao: Is there any solvent i can get to soften the gasket up, its stuck really bad on my cases, i got rags in the hole but kinda scared of getting shit in there... Does everyone have this problem? Im going to try the razor blade, then if it doesnt work ill try the dremel with a soft wire bursh.. use your rags and if you have a shop vac handy that would be a good idea to use to suck out anything else that might fall in there. I have used a few different things but normally it just takes time and a gasket scraper. I like them better then a razor blade but i might be a panzy. Quote
bentvalve Posted January 8, 2007 Report Posted January 8, 2007 yeah a nice putty knife sharpened on the end maybe a 2" one. also could use green scotchbrite. go to autobone there are solvents made for gaskets if they are on like metal.lol don Quote
Devans Posted January 8, 2007 Author Report Posted January 8, 2007 use your rags and if you have a shop vac handy that would be a good idea to use to suck out anything else that might fall in there. I have used a few different things but normally it just takes time and a gasket scraper. I like them better then a razor blade but i might be a panzy. Yea, i got some off with a blade and used the shop vac. I am going to pick up some of that gasket remover stuff tmo i guess and some scotch brights. Ill let yall know how it turns out. :thumbsup: Quote
