huh? i cant really tell where the bolt is stripped. but a reverse drill is usually a pretty good way to go. use that in combination with an EZ-oput and you should be golden.
depending how bad your screw got f'ed... get a impact driver! they are a MUST for any gargae banshee or not! they will save you from stripping those dreaded cover screws out... do your self a favr and order some replacement ss hex head bolt... cascade sells them, im sure others do too
