yamaha04 Posted December 10, 2006 Report Posted December 10, 2006 hey guys just wondering if anyone has tryed touching up the stock colored silver A arms if so what kinda paint and color did you use also where could i get the red metallic paint that yamaha uses on there frame in 04? Quote
BANSHEEMANIAC Posted December 10, 2006 Report Posted December 10, 2006 i used silver wheel paint on my frame. looks pretty close to factory color. not sure about the red though. Quote
kubiac3 Posted December 10, 2006 Report Posted December 10, 2006 Theres a paint company out that sells paints that match exactly to your bike. There called PJ paints or something, your dealership should carry them. They are spray cans. Quote
Mullet Man Posted December 10, 2006 Report Posted December 10, 2006 (edited) yep, RMATV has the PJ1 paints in their catalog... Edited December 10, 2006 by Mullet Man Quote
okbeast Posted December 10, 2006 Report Posted December 10, 2006 If you really want it to look nice I would recommend taking the arms off and sanding them a little, then clean them off really good with some soapy water, let it dry off real good, spray on a few coats of primer, then paint. This wouldn't really take that much more work and would help the final result last longer! Quote
yamaha04 Posted December 10, 2006 Author Report Posted December 10, 2006 If you really want it to look nice I would recommend taking the arms off and sanding them a little, then clean them off really good with some soapy water, let it dry off real good, spray on a few coats of primer, then paint. This wouldn't really take that much more work and would help the final result last longer! thanks guys so Rocky mountain sells the red paint on my frame aswell? Quote
BANSHEEMANIAC Posted December 10, 2006 Report Posted December 10, 2006 If you really want it to look nice I would recommend taking the arms off and sanding them a little, then clean them off really good with some soapy water, let it dry off real good, spray on a few coats of primer, then paint. This wouldn't really take that much more work and would help the final result last longer! make sure you do this! he is right, if you just spray them, they wont last. by the way i painted my swingarm and a-arms anodized red. looks really good. Quote
yamaha04 Posted December 12, 2006 Author Report Posted December 12, 2006 make sure you do this! he is right, if you just spray them, they wont last. by the way i painted my swingarm and a-arms anodized red. looks really good. thanks for the advise i looked in the rockymountain cataloge and only seen silver thats i all really wanted to paint anyway just thouhg i would get a can of red if they had it. i will probably do my A arms sometime this weekthe way you said i want it to last as long as posible Quote
