smokin 2 stroke Posted November 24, 2006 Report Posted November 24, 2006 would a esr 250 temp gauge work Quote
wesw Posted November 24, 2006 Report Posted November 24, 2006 this works and very cheap to build http://www.dunereview.com/Modifications.htm Quote
Satsol67 Posted November 24, 2006 Report Posted November 24, 2006 (edited) thats gay! Get a temp gauge from autozone then go to lowes and buy a T for the temp sender. If your worried about it vibrating then get the gauge that is water filled. I didnt care if it vibrates a little. I mounted mine in the front fender. Edited November 24, 2006 by Satsol67 Quote
Ryda85 Posted November 24, 2006 Report Posted November 24, 2006 thats gay! Get a temp gauge from autozone then go to lowes and buy a T for the temp sender. If your worried about it vibrating then get the gauge that is water filled. I didnt care if it vibrates a little. I mounted mine in the front fender. pics? Quote
Satsol67 Posted November 24, 2006 Report Posted November 24, 2006 (edited) I will take some tomorrow. you want to keep the sender as close to the head a posible. (sp) sorry. It cost me around 20 bucks and works great. Edited November 24, 2006 by Satsol67 Quote
jbooker82 Posted November 24, 2006 Report Posted November 24, 2006 Here is mine it is just an auto's temp gauge from a parts store. The temp sender just goes in to a brass T and there is a pice of pipe coming out of each end of the T. Just install it in line with your radaitor hose. I would recomed putting it in the top hose that way you get a more accurate engine temp reading. If you put it in the bottom then your getting a reading of what the temp is coming out of the radiator. Quote
Mullet Man Posted November 24, 2006 Report Posted November 24, 2006 (edited) where do you get the tee? Ace Hardware, Lowes, Menards. just get one that is made for higher temps i think that DIY setup is cheesy, utilizing a poultry temp guage lol. and still you are reading temps from the radiator, not temps in the exit hose out of the motor i would think when you are reading temps coming out of the overflow spout, that its too late... plus, being in the overflow path, that would require a constant flow wouldnt it? to get accurate readings all the time. Edited November 24, 2006 by Mullet Man Quote
sheefreak Posted November 24, 2006 Report Posted November 24, 2006 It's not in the overflow. I bet if you put a temp gauge on both hoses to and from the motor, they wouldn't read but a couple of degrees different. Quote
Mullet Man Posted November 24, 2006 Report Posted November 24, 2006 It's not in the overflow. I bet if you put a temp gauge on both hoses to and from the motor, they wouldn't read but a couple of degrees different. hmmm. i see now, looked like it was out the overflow. still cheesey IMO Quote
milo_32000 Posted November 24, 2006 Report Posted November 24, 2006 Anybody got a good pic of the tee ? I don`t want a BIG half inch water pipe tee like houewhole systems use ! Thanks , Milo_32000 Quote
Satsol67 Posted November 24, 2006 Report Posted November 24, 2006 Here is how I did mine. Sorry Pics arent the best they are from my phone. I went to lowes and bought the brass T then used a piece of hose to put the sending unit it the top. I'm sure there are better ways but this worked for me. Quote
jbooker82 Posted November 24, 2006 Report Posted November 24, 2006 Mine is somethig like this. I have two little pices of pipe on two of the holes so you can splice it in to the radiator hose. The 3rd hole is were the temp sender screws in to. I am not for sure what size it is though. I think that it would probably be 3/4 since that is what size the banshee's radiator hoses are. http://www.grainger.com/Grainger/wwg/itemD...emId=1612840205 Quote
RIPPEN Posted November 25, 2006 Report Posted November 25, 2006 Here is my setup.. http://www.bansheehq.com/forums/index.php?...p;hl=Temp+guage RIPPEN Quote
