can i have the outsides of my cyls. bead or sandblasted after the bore work is done?
ive seen a bunch of the bead blasted cyls, and have just decided to do it if i can i just got the cyls.
back from the machine shop.....
also can port work be done after bore work as well??
thanx for any input
Edited by BansheeDan
just tape both side or plug them... the beads or sand is going it work its way in the cylinders a little either way so your going to need to clean them either way you go but you dont have to worry about the beads messing up your new hone...
youll be ok,as long as you keep the bore taped good(i imagine the media will eventually wear through or pull the tape off,and try to use a fine glass bead media,not sand)i mysel prefer to beadlast the cylinders before i do anything...As far as porting goes,ive always ported after bore and hone(on iron liners)you figure you spent all the time porting it and making it perfect after you bore the cylinder its gonna change it all(very slightly).After you beadblast those cylinders clean those things out real good also.
Edited by Sprntr81
