Will i need to adjust anything else after I start the shee?
You shouldnt, the engine might run a little hotter, I have heard of some people going up a size on the mains to compensate, but I never had to, but youll really have to listen for it. Where on earth did you get camo plastics for your shee? I have never seen that before.
right on ...I ended up with 5+ should be fine right...Plastics are camoclaud decals...
Alright, I put new toomey pipes on yesterday put 290 mains in took the quad out ran it hard for about a hour. I checkes the plugs 3 times and looked perfect. I was disapointed with the lower end loss so I decided to take your guys advice and up the timeing. I finished up last night and it was late so I had to wait until today to fire it up. Ok new prob, I fired it up and instantly fould out the right side plug. I pulled both plugs out and left looks perfect right is fouled. I installed a new plug and same thing..Any advice?
I found that on my right side I have a leak in my pipe on one of the welds, would this cause the bike to run to rich?
i havent heard if a leaking pipes making it run rich...you didnt open your carbs or anything did you? if you did check and make sure you got matching jets... also make sure your float isnt sticking..
I did install the jets Saturday but ran perfect that day and I also just checked the ramaining jets and they are all the same. I will have to check the floats next...
I got the bike to run properly..What it was, no clue..I took the carbs apart today and cleaned everything up and blew it all out now runs perfectly. I assume something got in their or the floats may have been sticking...Thanks for all the input.
