wooten Posted November 16, 2006 Report Posted November 16, 2006 ok got all my wiring back together and i had cut the plugs off the tors on the carb and it acts like it doesn't get any gas but i had the tors unplugged for a while and it ran fine will cutting them screw them up or what Quote
locogato11283 Posted November 16, 2006 Report Posted November 16, 2006 ok got all my wiring back together and i had cut the plugs off the tors on the carb and it acts like it doesn't get any gas but i had the tors unplugged for a while and it ran fine will cutting them screw them up or what so what exactly is happening when you ride it? youre being somewhat vague. will it start and idle fine or not? kind of need more info before anyone can diagnose any problems. Quote
wooten Posted November 17, 2006 Author Report Posted November 17, 2006 i got it running last night but some of my packing is coming out of the pipes, will it hurt to remove the packing all together or do you have to put it back in there thanks for the reply Quote
Satsol67 Posted November 17, 2006 Report Posted November 17, 2006 I was wondering about the packing as well. How often do you guys replace it? And what happens if you dont? Is it just for sound? Or does it help with back pressure? Quote
LiftdT4R Posted November 17, 2006 Report Posted November 17, 2006 If you've got packing blowing out of your pipes, it is definately time to replace it. It should run even without packing, it'll just run like shit. The packing does help with the back pressure. If you roll it looser you tend to get a little more low end, while if you roll it real tight, the top end comes out a little more. Try searching on how stuff works for 2 strokes, it's basically the same concept as the exhaust acting as a valve. Cutting the TORS shouldn't make a difference unless maybe two of the wires are now touching, and you're shorting the system. Would need a little more info, I'd check to see how dirty the bowls are, and how clean the carbs are in general, pretty easy start. Quote
wooten Posted November 17, 2006 Author Report Posted November 17, 2006 ok i got it running i was just needing to know about the packing in the muffler where is the best place to get this stuff at Quote
