Bandit Posted November 16, 2006 Report Posted November 16, 2006 Im wondering what it would cost on average to powder coat a set of a-arms? Quote
kaotik1 Posted November 16, 2006 Report Posted November 16, 2006 Generally a-arms are cheap, around 25-30 dollars color pending, for each arm. So about 120 dollars. FYI you can not coat stockers though, because the ball joints are non removable. Quote
IROOST1 Posted November 17, 2006 Report Posted November 17, 2006 Generally a-arms are cheap, around 25-30 dollars color pending, for each arm. So about 120 dollars. FYI you can not coat stockers though, because the ball joints are non removable. How come you cant powdercoat stock a arms. If you take the boots off, it should be fine. Its all steel??? Just tape off the ball joints so they dont get coated. Quote
pipebomb Posted November 17, 2006 Report Posted November 17, 2006 they are baked at like 400* for around an hour. the ball joints tends to weld themselves to the socket in the A-arm in that kind of environment. Quote
Shee-Male Posted November 17, 2006 Report Posted November 17, 2006 ^^^^^ not to mention all the grease trapped in the ball joint Quote
kaotik1 Posted November 17, 2006 Report Posted November 17, 2006 they are baked at like 400* for around an hour. the ball joints tends to weld themselves to the socket in the A-arm in that kind of environment. Not quite 400 but 350-380 and yes the ball joints bind up afterwards. ^^^^^ not to mention all the grease trapped in the ball joint The grease is gone after the prep. but it will ruin the ball joint. I have a set I can show what happens after they go through the over. But cant post it till I get back from vacation. Quote
okbeast Posted November 17, 2006 Report Posted November 17, 2006 So WTH do ppl do to aarms? Just regular paint or what? Mine look like shit and i'd like to do somehting to them when I PC the rest of the frame. Quote
Mullet Man Posted November 17, 2006 Report Posted November 17, 2006 They upgrade, or paint yes. yeah, rattle can would be easiest. when you scratch them up again, just re spray Quote
06BansheeSE Posted November 18, 2006 Report Posted November 18, 2006 I just had some parts powdercoated from the guy on this site (TRG Coating) and let me tell you he did an awesome job and did it fast. Quote
