ok well im new here, and new to banshee's, my question is that when i shift to 6th it seems to not want to stay in the powerband,my set-up is a 4mil stroker 5mil long rod, cub cyl,cool head,vforce reeds,35mm carbs, im in sand on a 9 paddle buff, 15/42 gearing, what should i do to fix this or is it just normall :thanks:
Edited by SSmoked
normal operation for a Banshee.
I would suggest next time you are into the bottom end change to an RZ 6th gear and this won't happen anymore. The RZ gear is a closer ratio so when you shift into 6th it still will pull out to max RPM.
I am sure there are other opinions out there for this issue but that is what I would do.
Also that Cub motor should have no problem pulling even a stock 6th gear so I would find a dyno and tune it in better.
i just checked my gearing again and its a 15/40... i bought this bike this way so im still learning
15-40 gearing in 6th gear, really dont matter what tires your flying. your probably not able to pull that gear with the power, shift into 5th.
sand causes major drag on a bike.
i would say stay in 4th and 5th, you must ride in wide open dunes. in waynoka if your running 6th, i say good luck, too fast for them dunes imo.
stroker cub in 6th with 15/40 gearing ,hhhmmmm.....do yo ureally need to go over 90 mph much?
thats just plain scary IMO :ohmy:
Opposite the rz 6th gear is a longer ratio, geared to go faster, it will just make his problem worse.
dumb ? why are you wanting to go 75mph at the dunes.
personnally i fyour bike will pull 15-40 and you like it i would stick with it.
75mph is asking for a problem unless your drag racign and still thats hauling azz not being on a track. i wouldnt do it.
safety first imo.
safety first imo.
im not saying 75mph i was saying my bike made 75HP and im running a 22x11x8 8 paddle hauler buff and i have been told i need to go with at least a 10 paddle, it basically spins and gets no traction 1-3rd gear, i want to go faster on the low end, i use the bike for drag racing and the occasional top speed run in the open sand. it starts to stop pulling in 5th and then 6th falls on its face, keep in mind i weigh 250lbs. what are your sugestions?
man who set that engine up and what pipes do you have on it?? 75 hp out of a 4mill cub? alittle low I would say. and I dont think you need all that gear if you want to come out of the hole faster. get some super light 10 paddle extreams 22-11-8 with about 3-4 psi in them and hold on!
are you running race fuel? whats your compression? how much timeing are you running? I am thinking 15-44 gearing should work. I think thats where mine is at and I weigh 230
it has CPI inframes and i think right now im down to trying to figure the jetting corectly, i will probobly go to a 14/41 sprocket. so i definatly need a 10 paddle tire i guess
