LiftdT4R Posted November 11, 2006 Report Posted November 11, 2006 What's the best way to go about removing the front sprocket nut, I want to drop to a 13 tooth front sprocket, but I definately don't have a socket that fits the nut. You guys just use an adjustable wrench? Or does Yamaha make a special wrench for it? Thanks, Quote
Bansh-eman Posted November 11, 2006 Report Posted November 11, 2006 It's an 1 1/4 socket. its a metric, i want to say its 34mm or 36mm. it might end up being the exact same size as a stanard size, every few mectric sockets match the same standard ones. Quote
LiftdT4R Posted November 11, 2006 Author Report Posted November 11, 2006 (edited) It's an 1 1/4 socket. Are you sure??????? its a metric, i want to say its 34mm or 36mm. it might end up being the exact same size as a stanard size, every few mectric sockets match the same standard ones. That would be nice, because I probably have a 1 1/4 socket. My dad has a whole slew of abnormally large standard sockets that he gave to me. Anyone else know what size the nut is? I'm gonna run after work today to Sears, and just pick up the right size socket. Thanks, Edited November 11, 2006 by LiftdT4R Quote
David Keith Posted November 11, 2006 Report Posted November 11, 2006 What's the best way to go about removing the front sprocket nut, I want to drop to a 13 tooth front sprocket, but I definately don't have a socket that fits the nut. You guys just use an adjustable wrench? Or does Yamaha make a special wrench for it? Thanks, Yes it is 32mm, which is just a tad smaller than 1.250 inches. The american 1-1/4 will work fine. Quote
LiftdT4R Posted November 11, 2006 Author Report Posted November 11, 2006 Yes it is 32mm, which is just a tad smaller than 1.250 inches. The american 1-1/4 will work fine. Cool man, thanks, probably just stop by Sears on my way home. Always wanted to ask you, what's up with that pic in your sig? What the heck is that chick holding? Looks like broccoli or something. Quote
JET 99 Posted November 11, 2006 Report Posted November 11, 2006 worlds biggest morel mushroom?????????????? Quote
David Keith Posted November 13, 2006 Report Posted November 13, 2006 Cool man, thanks, probably just stop by Sears on my way home. Always wanted to ask you, what's up with that pic in your sig? What the heck is that chick holding? Looks like broccoli or something. It is the largest mushroom that our family has ever found! Eleven inches tall & more than four & a half inches wide... Quote
JET 99 Posted November 15, 2006 Report Posted November 15, 2006 holy sh...... what state was that in? Quote
LiftdT4R Posted November 15, 2006 Author Report Posted November 15, 2006 It is the largest mushroom that our family has ever found! Eleven inches tall & more than four & a half inches wide... Whoa, that's crazy! Quote
LiftdT4R Posted November 15, 2006 Author Report Posted November 15, 2006 you will also need an impact. Nope, there are a couple of ways around that. You can put it in gear and hold the flywheel, or, a way that I'm not crazy about you can leave it in neutral and bunch the chain up in the case, and it will come off that way. Did it a couple days ago, I had done a few, but always used a big adjustable wrench, wanted to buy the socket finally, but just couldnt remember the size. Quote
