Satsol67 Posted November 6, 2006 Report Posted November 6, 2006 I was wondering how much if any gain I would get going from a 22cc dome to a 20cc. I dont want to have to run race fuel. I would like to stay running 93 oct. I am in the proccess of doing a top end rebuild and would like to know if changing from 22cc to 20cc/19cc would make much of a difference. Also would i have to rejet? My mains are 280's now. Thanks Ron Quote
Animalman294 Posted November 6, 2006 Report Posted November 6, 2006 Going to smaller domes would deffinately get you more power gains, because you are increasing your compression. As far as runnin' 93, you need to do a compression check to find out. You eleveation plays a major role in this as well. If your compression is above say 155 you will need to run, at a minimum 50/50 race 93 or AV100LL and 93. You best bet is to contact NOSS on here and talk to him, and he'll hook you up with you options............. :beer: Quote
Satsol67 Posted November 6, 2006 Author Report Posted November 6, 2006 What compression should I expect with a fresh bore at 64.50 with the 20cc domes? I live in the Upstate South Carolina area. Is there a site that you guys use to check the exact elevation? Quote
Satsol67 Posted November 6, 2006 Author Report Posted November 6, 2006 if that is the case then 20cc domes should be fine running 93oct. Will i have to rejet? Quote
