Never seen any real tests but all I've ever seen is that the T-6's are more of a "mid" pipe and the T-5 is "mid-high" rpm. Also get an adjustable timing plate to advance the timing and raise your compression. Those will both help with the low-end :beer:
If you plan on getting portwork done and making your bike more of a drag bike T-5's
If you want an everything else bike .....Get the T-6's You wont be disappointed
If your motor is stock right now you would notice a big difference between the two, the T-6's pulling quite a bit harder
They have good all around power increases.
Good luck.
They look real nice too. My chroming was second to none..
Good luck.
Try not posting your question 3 times.. Your lucky if you get many responses because people will consider you a fucking retard..
Brad
I have ported engine 28mm flat side, v-force 2 and 3 ( don't know witch one is the best, probably the 3) +4 timing, cool head 19cc, I go trail riding alot more but when there is a long strait I want to be fast!!!!
T6's were designed to run at or near stock porting and port timings.
You can clean up and port the engines a little bit and T6s will work just fine.
But, if you're going very aggressive on the ports and timings, T5s are a better choice...
You might want to PM Lee, the board admin, and ask him to delete the other two posts...
While I'm not going to call you a fucking retard...I would advise you to use the search button.
Pipes are probably one of the most covered topics....and absorb what you read...
