my banshee takes like 20 kicks to start when its cold. am i doing something wrong? i have the choke all the way out...then halfway, still wont start. wtf am i doing wrong? anything i should check over? its pissing me off because once it is warmed up...it will start 1st or second kick! please help guys!!!
you may need a richer pilot jet... how is compression as well? Does it run good after it has been started and warmed up
the motor is all stock...and yes once it warms up, it runs great!
Before you take apart those carbs and fiddle with them, have you tried turning/adjusting the air screws at all?
Turn each air screw all the way in, count how many turns. Then, turn each one 1/2 a turn out.
If the bikes runs/starts really good...adjust them from there.
But, if you end up with 1/4 or 1/2 turn out, then....yes, you need a bigger pilot...
A. How old is this bike/motor....
B. Is it ALL 100% stock, as in stock pipes, stock air filter, stock aribox, lid, snorkle??
where do you live? Has there been a change in weather since this occured? Try going up a size or 2 on the pilot and see if it helps. Try turning the air screw in a half turn/ full turn and see if it starts easier as well, if so you need a richer pilot
there actually is no snorkel on there. but stock everything else. i forgot aboutt ehs norkle.
i live in hamilton, nj and when it started doing it i dont think the weather was changing? not sure though. :confused:
this banshee is a 97. same year motor.
:thanks:
its a 97 have you had it bored, new pistons, rings, what is your compression like????????
if its that old and no work done on motor my guess is its telling you that it needs some attention :blink::blink:
