Yaxy Posted October 5, 2006 Report Posted October 5, 2006 Allright guys, got the pipes on the rz and they fit fine to a point. In there current state when the front suspension bottoms the tie rod shaft just nicks the pipe. I have compensated with this by modfying the front hanger but when I try to put the stinger tube on the pipe and the tube no longer line up. I need to make up about .25" and the only way I think I can do this is to bend the pipe. I can eitther leave it on the bike and give it a good yank or take off the bike. Has anyone had expereince with this. Ideally I do not wish to chip the chrome so I am looking for any non crude way of doing this. Any suggestions? Thanks Chris Quote
BigRed350x Posted October 5, 2006 Report Posted October 5, 2006 Allright guys, got the pipes on the rz and they fit fine to a point. In there current state when the front suspension bottoms the tie rod shaft just nicks the pipe. I have compensated with this by modfying the front hanger but when I try to put the stinger tube on the pipe and the tube no longer line up. I need to make up about .25" and the only way I think I can do this is to bend the pipe. I can eitther leave it on the bike and give it a good yank or take off the bike. Has anyone had expereince with this. Ideally I do not wish to chip the chrome so I am looking for any non crude way of doing this. Any suggestions? Thanks Chris I would try and modify the tie rods before I did anything to my pipes. JMO. Tweak the tie rod, then re-adjust the things. Quote
Yaxy Posted October 5, 2006 Author Report Posted October 5, 2006 Thanks for the info. I would rather not tweak the tie rod shaft since I just bought new Quicksand arms and shafts. Thanks Anyway. Chris Quote
bigboybanshee Posted October 5, 2006 Report Posted October 5, 2006 I'm wondering if you might be able to put your silencer on a jig or something, heat up the stinger and bend it slightly to meet up with the head pipe...does that make sense? :shrug: Quote
Yaxy Posted October 5, 2006 Author Report Posted October 5, 2006 The stinger tube is a bit more hard to bend then the pipe due to the thickness of the material. Other than this small issue the pipes fit very well on the RZ. I am not sure they might be a perfect fit on the shee. Quote
twinscreamer Posted October 5, 2006 Report Posted October 5, 2006 The stinger tube is a bit more hard to bend then the pipe due to the thickness of the material. Other than this small issue the pipes fit very well on the RZ. I am not sure they might be a perfect fit on the shee. dud im stumped!!! i would try to heat the pipe up and give it a bit of a tug!!! : :beer: :beer: Quote
dawarriorman Posted October 5, 2006 Report Posted October 5, 2006 The stinger tube is a bit more hard to bend then the pipe due to the thickness of the material. Other than this small issue the pipes fit very well on the RZ. I am not sure they might be a perfect fit on the shee. ANYTHING will bend if you use enough leverage. Take yourself a good vice, pad it so you don't scratch anything, then slip a long pipe over the stinger. Use a little heat, and just move slowly, and you'll bend it. Quote
