Bansh-eman Posted October 2, 2006 Report Posted October 2, 2006 hey what chain lube , wax , oil or what ever else you guys use? the crap i use is too tacky and everything sticks to it.. need to use somethig new... Quote
addicted Posted October 2, 2006 Report Posted October 2, 2006 hey what chain lube , wax , oil or what ever else you guys use? the crap i use is too tacky and everything sticks to it.. need to use somethig new... i use a sillicone based lube. Simmilar to wd40, you can get it at any parts store. I started useing it for the same reason your describing. But I spray my chain every time I put gas in my bbike. Quote
Bansh-eman Posted October 2, 2006 Author Report Posted October 2, 2006 i use a sillicone based lube. Simmilar to wd40, you can get it at any parts store. I started useing it for the same reason your describing. But I spray my chain every time I put gas in my bbike. id rather use somethig that doesnt need to be sparyed that often but something that isnt mega tackey like the crap i have now... it seem like the shit i got now attracts things i the desert that arnt even there, ill come home with everything under the moon stuck to my case , case saver and chain Quote
2003LimitedBanshee Posted October 2, 2006 Report Posted October 2, 2006 I've been using Tri-Flow for years. It works great! It sticks around (unlike those that use WD40), but it doesn't create the tacky film the makes everything stick to it. I ride in the sand and never have a problem with sand building up. Quote
jbooker82 Posted October 2, 2006 Report Posted October 2, 2006 I use belray Super Clean. It doesnt really attract dirt. http://www.rockymountainatv.com/productDet...mp;navType=type Quote
