Ok, I want to be sure I'm in the ballpark on jetting because my local dealership sucks and never has the $3.00 jets in stock that I need so I need to order them.
It's a 1998 Banshee. Only mods are K&N dual pod filters with outerwears and a set of FMF fatty pipes and Titanium 2 silencers.
FMF's website gives some recommendations but it's with the stock airbox. I've been told that the K&N's pick up a lot over the stock airbox so I don't want to follow FMF's website.
I just put the FMF's on, and it came with the K&N's. Jetting right now was 25 pilot, 220 main and 1.5 turns on the a/f screw. I can tell that it's definitely lean right now, especially with the dropping temperatures.
I'm thinking 27.5 pilot, 3rd clip stock needle, 300 - 340 main. Does that sound close?
I put fmf ssts on and a single k&n with snorkel removed this summer and ended up with a 340 before I got what I wanted on a plug chop. Im at 1000' and it was about 70F outside. That is pretty big for some reason but you could start there and be safe.
i live in ohio around 900 ft level my friends and i are runnig around 270 to 290 jets depends on wether you run a lid and have your head decked but still on stock piolit 1 3/4 turns out,with my moto fast im running a 260 right now and its a little lean ,
Edited by thack
im running fmf gnarlys with no airbox lid and a k and n. Im running 300 mikuni mains with stock pilots (25). it runs great at wot but i need to up the pilot a size or two (27.5-30). try that. im at damn near se alevel no more that 100 feet above and the temp is really humid between 80-110 degrees. hope that helps :cool:
Edited by The Faster Cracker
340's a little rich for Fatties. Try 300 to 310 to start with. You may stay at 300 or end up at 290 but 340s are rich. 27.5 will work well for the pilots. Needle 4th clip.
