Ultimateduner Posted September 23, 2006 Report Posted September 23, 2006 While at D&M (a local banshee guy) I asked what kind of power I would gain if I switched to twin airfilters, he replied that I would gain about 3 hp . So asked why, and he said that on a normal K&n (big filter) the carbs fight for air so neither of them are getting the right amount. Is this true? Would I really gain 3 hp? Quote
dawarriorman Posted September 23, 2006 Report Posted September 23, 2006 Going from an airbox with the lid and snorkle on, to pods yeah you probably would, if you already had pipes that is. Quote
2003LimitedBanshee Posted September 23, 2006 Report Posted September 23, 2006 Agree with dawarriorman, if you had a complete airbox, even with a K&N element you would probably gain 3+ hp. With my T5's Toomey sent 280's if you were going to mod the airbox, vents and no snorkel, but running the 2:1 Unifilter setup, I ended up going with a set of 340's. So you figure the amount of air it takes to compliment 6 jet sizes and it should be worth 3 HP. Quote
Ultimateduner Posted September 24, 2006 Author Report Posted September 24, 2006 Yeah but I already have a K&n and my box doesn't have a lid..... Quote
ssanddemon Posted September 24, 2006 Report Posted September 24, 2006 This guy at D&M is a fatheadif he thinks that pods give performance gains- they don't. Actually a single filter should give slightly better performance in theory- since each carb sucks air alternately from the other, they don't fight each other for air. In fact, since the air volume is always kept moving rather than the on/off vacuum a single carb gives, there should be a bit of scavenging effect. The reason to run pods is ease of carb tuning; it's a lot easier to open up the carbs with pods, most of the time I never take em off when tearing the carbs apart. Quote
alcoholbanshee Posted September 24, 2006 Report Posted September 24, 2006 This guy at D&M is a fatheadif he thinks that pods give performance gains- they don't. Actually a single filter should give slightly better performance in theory- Ya thats why all us drag guys run air boxes.......they flow better!!!!!!!!!!!! LMFAO!!!!!!!!! Yes dual K&N's will give a horsepower gain, what that gain is will be determined by the surrounding mods. Quote
