IROOST1 Posted August 16, 2006 Report Posted August 16, 2006 I am almost finished building my banshee fromthe ground up and cant figure out where the hoses route to. The manual doesnt show a very good picture. I know there are two little lines coming off the radiator. Which one goes to the resivoir ??? And does the little line coming out of the case on the right side go anywhere??? HHEEEEELLLLLPPP, I wanna ride it this weekend... Quote
Bansh-eman Posted August 16, 2006 Report Posted August 16, 2006 the vent hose coimg out of the left side clutch cover goes to a T from there another vent hose at the top back part of the motor goes to the same T then th breather hose goes over the top of the motor to vent them both, the radiator hose from under the cap goes to the overflow bottle but to be honest you dont needit you can jst run the hose down the frame at the front and tie it off like i did. Quote
FireHead Posted August 16, 2006 Report Posted August 16, 2006 Do a search on the subject. I know there used to be a really good thread one here with pictures and everything. :baseball_mitt: Quote
firefighterjosh Posted August 16, 2006 Report Posted August 16, 2006 I removed my reserve tank. It is not needed. Just run the line from the top (next to the radiator cap) and run it to the ground. Quote
BenBB Posted August 16, 2006 Report Posted August 16, 2006 Stock ya got the small bypass line that goes from the head to a nipple on the top right of the radiator (right above the hose from the head). The overflow line below the radiator cap goes to the coolant bottle's lower nipple (or like firefighterjosh said ditch the bottle and run that hose straight downwards); the line from the bottle's upper nipple goes forward and points down somewhere in the vicinity of the right pipe expansion chamber. The vent line from the clutch cover goes to a tee (stock it's between the carbs); from the tee back the line goes to a nipple between the rear motor mounts, from the tee forward it just goes up and over a frame rail and points down. Quote
