if you follow the wiring from the grey boxes on top of your carbs that would be your tors same up on your thumb throttle, guess
what
i bet if you unplug those connectors you run across in the system you disable the system.
and if you need more specifics do a search in here there is a ton of info on tors. I think there are even pics somewhere in here
Follow the wires that go from the TORS units. They go to a little box under the gas tank.
Unplug them and remove the little box and throw that shit in the garbage and you
should be good to go.
:beer:
that damn tors is gonna be the death of me. is there a fast fix to get rid of it while i try to find an eliminator for it or am i screwd til lone comes in. point me in the right direction where i should look for one to
There is a TORS eliminator kit made by motion pro that I know of, there are other brands but not sure of the brand names. Disconnect all the electrical connectors in the TORS system and that will disable it until you get the eleminator kit. If I remember correctly vitosperformance.com has them. The TORS box is located under the left side of the fuel tank attached to the frame. If yo uneed any more help do a search and you will find more than enough info on this or shoot me a PM and I will do my best to help you out.
