Hey, just wondering if the Shifter Oil Seal can be changed with everything together, or do you have to take anything apart?
Thanks
Dinner :beer:
Thanks
Dinner :beer:
I just did mine. When I did it I changed the clutch also, so I had the clutch cover off. All I did was slide the shift shaft out enough to pry out the seal, then pop the new one in. If you don't want to take the clutch cover off, you may be able to still do it, but it will be more difficult. I bet you could use a slide hammer with a screw in the end. But since it is leaking the way I see it, it is a good idea to drain all the fluid and start with new, so you know you have the right level and such. Either way, not a very hard job.
In fact search on here a bit, there is a few posts about just this.
lol I just changed my clutch also and its still apart so ill just wait until i get the seal :beer:
