BansheeMxer#45 Posted June 30, 2006 Report Posted June 30, 2006 for the best bottom end power what size spockets you guys think i should go with . 12-41? or 13 -44? or other? when im racing mx i never hit 6th gear and very im mean very seldom do i hit 5th. normaly 3 and 4th so what u think thanks for any info Quote
locogato11283 Posted June 30, 2006 Report Posted June 30, 2006 i wouldnt go any smaller than 13 up front. if you wanna go lower than 13/44 i would suggest a bigger rear sprocket. i understand what youre trying to do. you wanna have a wider range of lower gears for the track since you never hit 6th? even with 13/44 youll prolly still never hit 6th. id try 13/41 or 13/44 and see how u like them. depending on what year banshee 41 might be the stock rear sprocket. if so on yours, try the 13/41 first and see how u like it. Quote
Animalman294 Posted June 30, 2006 Report Posted June 30, 2006 Loco is right stick with the 13 front, because 12 is really hard on chains (tight turn). You can adjust the back to get where you want to be. A 12-41 puts you at 3.42:1 13-43 puts you at 3.31:1 13-44 puts you at 3.38:1 13-45 puts you at 3.46:1 This way you don't bind your chain up so much............ Hope it helps :beer: Quote
BansheeMxer#45 Posted June 30, 2006 Author Report Posted June 30, 2006 i dont realy know what them numbers mean lol could u enlighten me Quote
locogato11283 Posted June 30, 2006 Report Posted June 30, 2006 i dont realy know what them numbers mean lol could u enlighten me what numbers? Quote
BansheeMxer#45 Posted July 1, 2006 Author Report Posted July 1, 2006 3.42:1 3.31:1 3.38:1 3.46:1 ?.??:? Quote
EastCoast Banshee Posted July 1, 2006 Report Posted July 1, 2006 first number is how many turns the front turns before the rear makes a full revolution Quote
2003LimitedBanshee Posted July 1, 2006 Report Posted July 1, 2006 Like Eastcoast said, it is the ratio of how many revolutions the front sprocket makes for every one revolution the rear sprocket makes. The bigger the number the more mechanical advantage the engine has, and the lower the gear ratio. This doesn't truly give the bike anymore bottom end, what it does is give it more advantage, which will make it better out of the hole. Think 1/4 mile drag race vs. Bonneville salt flats. Drags run much lower ratios so they come out fast, but they peak very fast too. Salt flat cars have to be pushed in most cases because they have such high gear ratios but they pull forever. Quote
