I'm pretty new to banshee's, and hoping to get one pretty soon. I'll be upgrading from my blaster, which I cant wait to get rid of... so out grown of it. Anyway, the group I ride with consists of a piped 400ex, some warriors(all stock), and some stock cr250f's. I basically was wondering if a piped 'shee could handle all of these in drag-style races.
Let's just assume you and all your riding buddies are all of equal fairly good riding skill, I would have to say you might want to keep a magazine or sumthin' under your seat. Because your gonna spend an awful lot of time waiting for them to catch up.
The warriors should be very easy to beat and once you pipe the banshee you should be throwing alot of dirt/sand at the 400EX pretty easily also.
This is going to be a big change from a blaster to a banshee.It may take you a while to get use to it.It will be worth it. :clap:
Well a stock Shee should beat a Warrior and a 400ex. if you slightley mod the Shee (Pipes, remove the TORS, and go to K&N pod air filters) you should be able to handle most stock thumpers up to 450cc. depending on your skills. When my Shee was stock and just had the above done to it, I was beating stock and piped YFZ 450's all day
I doubt you'll be able to handle them...unless they can't ride.
Damn near the same HP out of the box...( I think they have mid- to high 30's) and less than half the weight...
