well theres a couple different things you can do really. you can paint them with the fusion paint for plastics (walmart or autozone) it works allright but you really have to do it right. if you just want to clean them up of scuffs or old dirt. just use the ever so handy magic eraser. the little son of a bitch cleans plastics very nice. put a little pressure on it and it will take off any dirt or scuffs. other than that you can buy new ones
I guess plastic renew works good, for white plastics some comet power and a brillo pad or such works good, and if all else fails some fusion paint but you gotta do alot of prep to get the fusion to work right. Its held up good on my tank and rad shroud suffered some small gas spills fine only bad part is where the seat rubs and thats a given. My only complaint is I couldnt find some clear coat fusion paint and the finish without clear is kinda rough looking. :evil:
SAND SAND SAND, rough grit to light grit, take out all the deep scratches, then make the whole thing in a fine rough stage, enough to hold paint but not too scratchy that it shows through, and clean clean clean especially if you used "armorall" type polishes on your plastic. Prep is the most important part to painting anything (cars, bikes, quads ect.) If you do it right the paint will hold and not flake off. and you need a flexible paint.
yeah.... i am a paint and body student so i know how body work... but the primer i'm using isn't thick enough to stand 180 grit much less anything rougher, i'll be blocking the paint down tomorrow and doing a marble effect followed by clear so it should last a little while... like i said its all temporary until i can get a lttle more time and equipment to do it right
  • 3 weeks later...
