420_Big_Bore Posted May 12, 2006 Report Posted May 12, 2006 Im interested in buying a swingarm or axle from andy, but cannot afford both right now so im interested in what would be best to get first? Which would help me the most? Quote
lonestar Posted May 12, 2006 Report Posted May 12, 2006 (edited) IMO axle your useing a 6" swing- arm now. The longer you go less traction. They got a sale over plant-sand on billet drag axles this week . I think it ends 5/19/06 Go to www.plant-sand.com for $425.00 can't go wrong. Also I like your bike Edited May 12, 2006 by lonestar Quote
jesse1004 Posted May 12, 2006 Report Posted May 12, 2006 Definately go with the axle! rotating weight robs more hp from you than still weight. Losing seven pounds of still weight is equal to gaining 1 hp, but losing 1 pound of rotating weight is equal to losing eleven pounds of still weight. Do the math on that and you gain about 1 1/2 hp from that one pound. Quote
420_Big_Bore Posted May 12, 2006 Author Report Posted May 12, 2006 Thanks guys! And lonestar, im not sure if you read my other post but at the moment i am having a problem taking off in 2nd, so would lengthening the swingarm help me or not. And, or will the lighter axle help me? Ps. thanks for the compliment! Quote
lonestar Posted May 13, 2006 Report Posted May 13, 2006 Thanks guys! And lonestar, im not sure if you read my other post but at the moment i am having a problem taking off in 2nd, so would lengthening the swingarm help me or not. And, or will the lighter axle help me? Ps. thanks for the compliment! 515309[/snapback] Any weight that you save that the motor has to turn tires, axle, rims, hubs, chains etc. I think imo would be a better benefit for horespower & torque like Jesse 1004 said. Lengthening the swing arm has lesser benefit yes it probably get the tires spining better starting of in 2nd gear. Is your gearing correct for what you want to do? Is your jetting spot on? Pilot, Your L1, Diameter of needle, that comes into to play comeing out the hole. If you think it's correct. I'd get the axle before the swing-arm. This is my opinion Quote
420_Big_Bore Posted May 13, 2006 Author Report Posted May 13, 2006 By the way, my swingarm is the original. All i did was chop it and welded an extra 6inches tubing on, so before i go buying a new one i decided to play around with mine. To be able to take off in 2nd ( as currently it is bogging) would i need to lengthen or shorten? Quote
lonestar Posted May 13, 2006 Report Posted May 13, 2006 By the way, my swingarm is the original. All i did was chop it and welded an extra 6inches tubing on, so before i go buying a new one i decided to play around with mine. To be able to take off in 2nd ( as currently it is bogging) would i need to lengthen or shorten? 515473[/snapback] It's the rear tires thoes are 22" and with a 15 tooth front sprocket your motor don't have enuff torque to get rid that bogg Quote
420_Big_Bore Posted May 13, 2006 Author Report Posted May 13, 2006 with my pro circuit pipes i was running 330 main jets, and still have them in with the grr drag pipes. should i put bigger jets in as i have 300's and 350's? Quote
89Steeda Posted May 14, 2006 Report Posted May 14, 2006 I see you have an original style Banshee carrier. If you go with the 40mm drag axle, you 35mm stock carrier will not work. Quote
