420_Big_Bore
Everything posted by 420_Big_Bore
HELP! Banshee not running right
420_Big_Bore replied to 420_Big_Bore's topic in Banshee Repairs and Mods
Sorted out the problem, it was the rubber gromit on the boost bottle. The old one was split and was leaking air in, so replaced and running perfect! Thanks for your help. -
Carb boots are fine, before i pulled it down it was running perfect, but ill check the jets. -
Hi guys not sure where to post this but i really need help. I just got my windows in my pistons ported bigger and built the motor back together, but i just started it and its revving really high and only on 1 cylinder. When i push the choke down then it stops. Can anyone help? Thanks!
I was planning on keeping the cast for now until i do go bigger bore or unless these fail. Just wanted some opinions on both sides, and to see if these are ok for now. But looks like my next set will be forged. Thanks for all help.
Cheers. Just needed an opinion. Later on i will get forged when i go to stroker.
Hey guys, i wont go into whole story just cut it down to this. I got a set of Pro-X 68mm cast pistons in my shee. Just wondering will forged pistons make that much difference? Seeing as im not doing any further mods at the moment i was wondering would i be wasting money on a new set of forged pistons when i already have new casts in? Cheers
I've just been told that wiseco dont make 68mm pistons for stock cranks, only stroker cranks.??
Does anybody know where i may be able to purchase some 68mm Wiseco Pistons for a big bore? Ps: I live in Australia.
Ok thanks heaps for your help i will do a plug test this week end and let you know how it went. And if my plugs were black would i need to go down in jet size? Or could it be too much oil in the fuel?
the BR8ES had oil on, but i havent done a recent plug chop. What do i need to do if it is oily? and what do i do if its black but dry?
Ok will do that this week end and let you know. By the way i am using NGK BR8ES plugs, not sure if they are similar to you guys?? Do you run hot or cold plugs?
Nah i am using the 34mm carbs and yes the jetting is definitely too small (for drag pipes), i was just wondering what size i would need to jump up to from 330? And anything else i would need to change?
Yeh 330's were for the setup i had before i got the drag pipes. Ok so if my plugs are black oily / or black dry what would i need to do? I've never heard plugs of being brown?
Well i had a stage 2 port job and then i got a 409cc Big Bore Kit. I live in Australia and somebody in Tasmania done the work for me and said to run 330's (with the bigbore kit and pro's). He said he didnt know much about drag pipes so thats why im askin you guys. Im guessing a set of wisecos will make a bg difference as well? Wow 400's, thats a big jump. Yeh he did have a site, grandriverracing.com but i cant find it anymore?
Yeh i realise that now, but i couldnt find any 68mm wiseco's around. Might have to ask round. Well with my pro's and the setup i got, the mechanic told me to run with 330 mains.
Hey guys havent been on here for a while. I just went to the dirt drags yesterday and chucked on my grr dragpipes, and i found they perform less than my pro circuits, eg:I cant take off in 2nd withh the drag pipes but i can with pro's. Know i have recently blown a piston and replaced the old wisecos with pro x racing (bad mistake) they have much smaller windows. Could this be my problem as i know drag pipes need more fuel. Also any other mods i could do to improve the performance with the drag pipes? Ps: Does anybody know if andy has closed down? Cant seem to find his site.
Ok Thanks. Do you know a rough price what they cost?
Hey i originally had wiseco pistons in my bike but when a piston broke the only pistons i could find to replace them were pro x pistons. I've realised i've lost power as they do have small windows, so i want to go back to wiseco. Does anybody know where i could find a set of 68mm Wiseco pistons?
Thanks guys for the help! Where would i be able to purchase a nos kit from?
I'm thinking of putting nitrous on my bike. Now i won't be using it alot, as i know engines can go. It will be for looks as well. But as i am new to this subject any body who has experience on this topic, i would appreciate any info. Like is there a button or switch to activate, What gear to use it, Where the best place to order it from, Any other mods required. Thanks.
Thanks for that, will try it and let you know how it goes. Cheers
Yeh i wanted to order wiseco's but nobody could find me any in 68mm size I guess i'll just have to try a day with it geared high for 1-4 and then gear lower for 2-6. Trial and error. Thanks for all your help!
Yeh 200m is slightly longer. The problem i had was my piston broke (wiseco) and so i bought 2 more (prox racing) and i noticed these had smaller windows which reduced the amount of fuel, so im not sure what to do now. And what would happen if i geared the bike for 1-4? Would i be loosing power?
I know i have asked this before but i kept getting different answers. I race on 200m dirt track.I originally had 20" dominators with 15-41 gearing and was able to take off in 2nd easy! But ever since i put on 22" pro wedge's and the GRR drag pipes i have been having problems (bogging). I was thinking of taking off in first but i thought that it would be better to top the bike out in 6th to acheive the use of all the gear ratio. As when i take off in 1st, i cross the line in 5th. So should i go back down to 14-41? Or gear it up to like 16-40 for 1st to 5th. Help is much appreciated
i race 200m. So it doesnt matter if you cross the line in 4th? I always thought its best to cross the line in top gear, top revs.
