Finally got the lockup clutch and cover installed and now the darn foot peg will not go on. The foot peg hits the clutch cover. Anyone had this problem?
you could possibly cut down the foot peg a little or get a little bit longer bolts and cut some spacers for it which is the route that i went because my pegs are chromed..
www.directdrivecnc.com
They make some pegs that will most likely bolt right on. From the pictures, it doesn't look like they are very "beefy" though.
Are you using Direct Drive units as that is what we sell and dont have much problems . Just need to adjust the brake lever alittle and that is it.
I thought about spacers. I wonder if someone makes a foot peg that will bolt right up?
512697[/snapback]
i got aftermarket foot pegs with the case and yes u gotta grind away and i added spacers aswell..... u can see just how close the clearance is in this next pic
That's nuts...mine went on fine with the stock pegs, no spacers, no grinding, no problems. :shrugani: I got about a quarter inch clearance between the peg and the cover. Weird :huh:
I do need to adjust my brake lever though, it barely rubs the bottom of the cover
