ajsproaudio Posted May 4, 2006 Report Posted May 4, 2006 I am going to put my Crank Case Cover back on and Don't know what oil it takes or if it takes any special kind... Any Suggestions. I have a 98 Banshee stock engine with V-force reeds and Pro Circuit Pipes... Quote
Big Blue Posted May 4, 2006 Report Posted May 4, 2006 80w gear oil, regular motor oil, tranny fluid take your pick. Quote
dajogejr Posted May 4, 2006 Report Posted May 4, 2006 1. Clymers manual is the banshee bible....all this info is in there. 2. This varies...some will say ATF, gear oil, hydrallic oil, etc. I personally have always used Bel -Ray Gearsaver 80W oil...never hand a tranny problem in any of my 2 stroke transmissions. As long as it's not Crisco.... Quote
ajsproaudio Posted May 4, 2006 Author Report Posted May 4, 2006 The Local Yamaha Shop Told me that I coul dprolly use 10w 30 Car oil. I want to use what the machine requires or what is best for it. I will use 80w gear oil if that is good for it but I don't want to use it, If it is gonna wear out quicker. I need a honest answer from a person who uses what they are telling me to use... Quote
Big Blue Posted May 4, 2006 Report Posted May 4, 2006 I have always used 10/30 or 10/40 motor oil and have never had any trouble from it. Gear oil doesnt break down as quick but in cold weather you need to like the bike run and warm it up before riding, tranny oil works great also you just need to change alot more often. Quote
ajsproaudio Posted May 4, 2006 Author Report Posted May 4, 2006 Ok well I am gonna go and buy Mobil 1 Synthetic 10w40 motor oil. My next Question is How much does it Require? Quote
dajogejr Posted May 4, 2006 Report Posted May 4, 2006 DO NOT buy car oil. They have special detergents for keeping a motor clean... Buy some gear saver or other oil designed to be used in two cycle engine cases. 80W gear oil for motorcycles works just fine in the winter... It's compatible or comparable to 10W40 oil..viscosity/weight wise... Quote
Ducman Posted May 4, 2006 Report Posted May 4, 2006 Ok well I am gonna go and buy Mobil 1 Synthetic 10w40 motor oil. My next Question is How much does it Require? 511958[/snapback] You absolutely do not want to use Mobil 1. It has friction modifiers that will help your clutch slip. It is best if you can buy gear oil made specifically for a 2 stroke motorcyle gear box like 80w Bel Ray or Maxima gear oil, but 10w-30 or 10w-40 4stroke engine oil will work fine, but just get the cheap dynosaur oil, not the synthetic stuff. Quote
ajsproaudio Posted May 4, 2006 Author Report Posted May 4, 2006 Ok then 80w Gear Oil. How Much Does the Case Require? Quote
KlotzBanshee Posted May 4, 2006 Report Posted May 4, 2006 I've been using the Bel Ray 80w clutch saver for years with no problems w/ clutch or trany. You may have to change it more frequently, but so what. cheap insurance if you ask me. 1500cc cap. its like 1.6 qts or 1.5 L ....something like that. Buy a manual asap. Quote
dajogejr Posted May 4, 2006 Report Posted May 4, 2006 Thanks...ducman, that's what I was trying to get at. It takes 1500ccs. So...it'll end up being between 1.5 quarts and 1.75 quarts.... Quote
Ducman Posted May 4, 2006 Report Posted May 4, 2006 Ok then 80w Gear Oil. How Much Does the Case Require? 511974[/snapback] For gear oil change 1.6 Quarts or 1.5 liters After taking the clutch side cover off it takes 1.8 quarts or 1.7 liters Quote
dajogejr Posted May 4, 2006 Report Posted May 4, 2006 Could always use that dipstick thing...too... Quote
ajsproaudio Posted May 4, 2006 Author Report Posted May 4, 2006 Ya I plan on using the Dipstick. I just didn't know how much to buy. I don't wna tto buy too much. The wife yells as it is for spending $24 in changing the oil seal. and Case gasket Quote
csrmel Posted May 4, 2006 Report Posted May 4, 2006 i went with shell rotella 5w40 synthetic at walmart for 3 bucks a quart. diesel oils like rotella are quitable for wet clutches, it says so right on the back. Quote
