racer Posted April 15, 2006 Report Posted April 15, 2006 can you test for fuel flow? no shit you can pop off the line and see if it comes out, but is there a way to make sure thats enough? Quote
hittintrees srh Posted April 15, 2006 Report Posted April 15, 2006 if a lot is flowin out....your good. Quote
Wallrat Posted April 15, 2006 Report Posted April 15, 2006 I guess you could just run her WOT and then turn the fuel off. If there's enough fuel flowing then there should be enough in the bowls to keep you going for a little bit. Quote
locogato11283 Posted April 15, 2006 Report Posted April 15, 2006 pop the line off and see if its flowin fast. if the stream is the same as the ID of the hose then id say you got good flow... Quote
racer Posted April 16, 2006 Author Report Posted April 16, 2006 I guess you could just run her WOT and then turn the fuel off. If there's enough fuel flowing then there should be enough in the bowls to keep you going for a little bit. 502547[/snapback] that'll work well enough for me. Quote
