:P Hey guys whats up?.. I have a 100% Stock 02 Banshee fully rebuilt engine just looking to get some low end power i have been told that they are known for this.. but what easy mod's can i do to help get away from this problem?. just looking for a bit more get up and go off the line i just use it as a trail machine or in the pits that kind of stuff.. anyways any suggestions would be great
Mike.
:jesterlaugh:
You could go w/a thirteen tooth sprocket for a cheap helper. If you want some serious low end, get some PT mids, bump your compression, a two into one carb kit, and if you want to get extreme, get some low end porting.
499803[/snapback]
All the same things I would recomend..
RIPPEN
I run a 13 front and a 44 rear lose alot of the topend but in the woods and stuff it's sweet..
Lighten the flywheel, also helped get past the bottom alot quicker..($70)
I have Toomeys and I get hardly any low end sputter... I usually keep it above that part of the throttle anyhow. Use the bump bump throttle technique myslef...
Other than the flywheel, the T-5's, weisco Superlights and the cool head with 22cc domes I am stock...
Out at the dunes I would just run out of gears, I was taking off in 3rd while drag racing I had to go back to 14 in the front , but in the woods I run the tight trails usually in 2nd and 3rd...
If you're getting into the sport seriously, larger displacement + more compression = more torque, more torque = more low end.
u could also bump your timing up take the timing plate off and slit the 3 holes so u can turn it clockwise about 1/8 in that is free hp
wow thanks everyone for the quick responce's i may have to try a few of those ideas i know a guy with a set of T5's for $300 he just sold his banshee without the pips and silencers and he has the jet kit for it to so maybe ill give that a little try for now.. I live in Ontario canada wedont have dunes or id spend tones of money on this thing just forest and trails and stuff so just looking for a bit more fun in the woods without haveing to scream the crap out of it to make it work.. anyways thanks again :) any other ideas just drop them by
Mike
