CadillacBanshee Posted April 8, 2006 Report Posted April 8, 2006 I just had the stock clutch shatter on me. I had it changed to a heavy duty tusk. The gearing on my bike is 14/42 and i ride in sand mostly. Should i gear down a bit and go with a 14/43? Does this affect the clutch at all? I dont want to loose that top speed. Quote
Master of Faster Posted April 8, 2006 Report Posted April 8, 2006 No, as long as your clutch parts are in good condition and everything is adjusted properly you should be fine, I run 16/41 most of the time without problems, I did have clutch problems last year that were due to a worn clutch basket, switched to billet and all is well, good components make all the difference. Quote
creamsickle Posted April 8, 2006 Report Posted April 8, 2006 no gearing shoudl not affect the clutch. I run 14 44 and it runs great. I also went to a billit basket. you may of had your clutch cushions go out or the idler gear bushing went out and it slipped and chowed your basket. I have a used stock basket without gears if you want it. like 45bucks shipped. Quote
