ron80banshee Posted March 27, 2006 Report Posted March 27, 2006 (edited) I need some advise on jetting. The bike is mainly stock with T5's, and K&N Powerlid. I have 340's in right now. The bike will start only w/the choke on even when warm. The right side cylinder seems to be burning lean. The bike will not idle. Should I be running bigger jets? These are my first mods to the bike. Please help! Thanks in advance. Edited March 27, 2006 by ron80banshee Quote
Wicked98Shee Posted March 27, 2006 Report Posted March 27, 2006 (edited) try some 30 pilot jets and the 4th clip on the needle Edited March 27, 2006 by Wicked98Shee Quote
04YAMSHEE Posted March 28, 2006 Report Posted March 28, 2006 DEFINTALY NEED TO GO UP ON THE PILOTS! I HAD THE SAME PROBLEM, PUT IN SOME 30 PILOTS AND PROBLEM SOLVED! Quote
biggun6ss Posted March 29, 2006 Report Posted March 29, 2006 Before you go changing out your pilot jets try adjusting your air mixture screws. For the idle adjust your idle screws until it will idle without the choke on and make sure the slides in the carbs open and close at the same time. Quote
