Hey,
I have a 1996 yamaha banshee and We just had the engine rebuilt and to do so I took the engine off and thus removed the clutch calbe. Now since I have put the cable back on my clutch has been really hard to pull.........any suggestions?
How do you lube the clutch cable?
Edited by banshee122386
Lube , Lube , Lube ! Or just get a new one there pretty cheap . Just be sure to lube that one :D If they did rebuild the clutch too , than yea stiffer springs could do it, you can alternate the springs , 3 stock , 3 stiff...
Edited by crazywheelerman365
Also make sure you have the cable running smoothly down through the frame, etc to the clutch, when i re-built my banshee i did the same, but then relized i had put the cable to much on an angle :confused: so i fixed it :cheers:
Edited by Dinner
