banshee122386
Everything posted by banshee122386
  1. My banshee is having problems running, One cylinder is not firing as much as the other and i don't know what to do
  2. How do you lube the clutch cable, and how do you clean it, because mine is really hard to pull
  3. I have a 1996 Yamaha Banshee and I rode it for a half hour the other day, and the next day I go to start it and nothing......Spark plugs are new, Gas is new, carbs were just jetted, Carbs are clean, no TORS, what the hell is wrong with this thing? Ok now it will start but it runs really rough... It feels like one of the cylinders doesn't kick on unless I gun it what is goin on?
  4. Hey, I have a 1996 yamaha banshee and We just had the engine rebuilt and to do so I took the engine off and thus removed the clutch calbe. Now since I have put the cable back on my clutch has been really hard to pull.........any suggestions? How do you lube the clutch cable?
  5. Also my clutch lever is really hard to pull where can I loosen it at?
  6. I also heard someone say something about the parking brake on banshee's......Something about an electrical connection that causes starting problems if not all the way forward or something....On mine there is something already done to the brake so it can't engage so i don't know what i would do? If it is electrical where should i start? Does anyone know how much a new coil and new stator would be for my 96 shee? After the engine was rebuilt I forgot to put the bolts back onthe stator cover and it was only on by one bolt is it possible that it effected the starting of the banshee? How hard is it to remove the TORS?
  7. whenever it won't start without starter fluid gas leaks out from everywhere and it eventually gets flooded.........and I have checked the plugs many times and also have fooled around with the pilot screws trying to get it to run. I also replaced the choke tube and still sometimes it just doesn't want to start.
  8. I have a 1996 yamaha banshee and it has a rebuilt engine on it....A friend rebuilt it but then i took it to the professionals after to check it out everything was fine and it fired right up....i let it sit a while and now it will start with starter fluid one day and run fine then the next not start at all.........not even with starter fluid.........spark is there,gas is new, and i don't know what to do now?
