just rebuilt top end installed 68mm wiesco pistons ,top notch cool head w/19 domes,ported intakes,lifted exhuast port 1mm,took off rev control boxes off the stock carbs and left switches unpluged installed moose carb caps and throttle cable.installed 190 main jets ,pro tech billet intake with boost bottle(i know wast of money),v-force 3 reeds,pro design airfilter kit,fmf pro curcuit pipes,vitos clutch and springs,running 93 octane 32:1 mixture. at top end i hear a ping/taping ratling sound.if i let off the gas it goes away if i only run 3/4 throttle or less i dont hear it. please help!
also throttle is stiff no kinks in cable routing just nice big curves and thumb still killing me
once i fix this problem i was thinking of getting a smaller stator w/highoutput and timing plate set at 4 degrees advanced. good idea or bad idea?
thanks
Edited by gixxerider
thanks
489945[/snapback]
Well....for one thing, your main jets are too small.
And you may need to run a higher octane fuel with those domes. :shrugani:
I'd ask whomever did your porting for jet sizes.
I have to run race fuel with my 19cc domes.
Sounds like you may be detonating.
190 mains? I was running 310's with just pipes and K&N, sounds like you are lean too.
+4 timing with that much compression + 93 octane = Bad Bad Idea.
Edited by Justintoxicated
The jetting really depends on your elevation, I doubt the pinging it a jetting issue you need higher octane gas... at least run 50/50 pump and race gas.... if you chime in with your elevation we can help better with the jetting... also what pipes do you have? You said FMF Pro Curcuit.. those are two different brands.
i had the same problem, but with just the right side. im also running the single carb, so ive been thinking of going up in my jetting and start running 118 oct. b/c of my 18cc domes. and good luck on the throttle. take the springs out and cut them down a little.
  • 3 months later...
i just ran into the same problem today, been running fine since i got it, compression is fine
it has
fmf fatty, SST silencers i think (unmarked, just what i was told)
pro design intake and filter with outerwear filter
pro design jets (so i was told)
boost bottle
i just had the local shop tune it in may and then yesterday i went out,
let my friend ride it up a medium hill climb , i got on it and it was pinging pretty much at the powerband or shortly after (which may actually be all the way up there since once it hits its gone!)
but other thing is this was a fresh tank of gas (i buy 93 octane i think, its the highest stuff at this Turkey Hill nearby) and i use super-m stuff, synthetic 2 cycle racing oil (5 gal gas : 16 oz oil, 40:1 i believe ....always bought from there before, never a problem
my other friend whos never owned anything with a motor besides his car says to richen it ... i dont think thats the problem
i have all stock insides excapet the impellar.
could it just have been hot from the hill climbs? althought on the way home its a pretty far flat stetch it shoulda cooled down, i rode home under the powerband just to be safe
Edited by aaron913
it has
boost bottle
Ok whats your compression?Ilike 32;1 but 40;1 is ok.Check your plugs to see if ur runningrich or lean light is lean and dark is rich.
so go bigger jets maybe 300-310 and
better fuel .what octane
hey thanks for the info
105 or so
FYI,
the 32:1 or 40:1 oil mix ratio is completely dependent on the oil you are using.
I run 50:1 but if I didn't tell you what kind of oil, and someone did that with Yamalube or something, that would be BAD NEWS.
Pinging is definitely the sign that you need higher octane gas, and you should run your oil at the mix ratio ot was designed for.
I run AMSOIL DOMINATOR (formerly Series 2000) at 50:1 and I've NEVER had an issue.
FYI,
Really? I have been running AMSOIL at 40:1 and I was wondering if I could mix it 50:1.
I am running t-5s, k&n pods, 4 degrees advanced timing, cool head with 19cc domes, VF 2's, and a dune port with the stock carbs. I have been using klotz r-50 mixed at 40:1 with good results. As far as jetting At sea leve or close to it I run 360 mains and stright 110. At 4,000 ft I run 330 mains and mix 110/91 half and half. I fiqure that my bike is close to your so that will give you a good idea at what jeting to start at.
